I was wondering what cable type you use in the UK for supplying a rotary switch from a 3 phase board. Installation from board to wall mounted rotary switched via 20mm conduit. I know for domestic you use grey flat cables.
Hi Westward, Thank you very much for your quick response
:) . I often come across doubts as I was qualified in Germany and Scandinavia and the materials we use theremay be very different.
I have just checked. These are single cores, how about multi core cable runs?
Why would you?
I am thinking of 2 options: 1. using trunking from the cabinet and pull multicores for each circuit and run down to the switch points. 2. Use cable tray all the way round the hall, and run multicores down in conduit to the switch points. This is normal practice in Germany and Denmark. This is the reason I want to know what type multi cores I need. Flat cables are a no go.
Well you asked what cables we use in the UK for conduit. Why would you employ methods from Germany or Denmark in the UK, not suggesting they would not be viable.
Well, I believe running singles in conduit can damage wires and also singles have a shorter life expectancy. I am just interested in the type of cable you would use, let us say you want to run on a cable tray, or trunking. That is it really.
Some of the things you do in the UK are based on traditions. One example is flat cables. no where on the continent they use flat cables for power. Historically, I know this came in the UK during the war to save materials, but you see, it stayed for decades until today. No one asks about it anymore. Imagine running flats on a cable trays or through PG glands into cabinets. with all those naked CPCs ... So, a lot is tradition as well.
All I like to know is the type of round PVC cable I can run on a tray around the workshop? otherwise I will need to import from Germany
:cool:
Properly installed conduit should not damage singles, the point of it is to protect wiring. Work here must be done to BS7671, if you choose to install from another standard this could be a departure, you would then have to demonstrate that's its not less safe than our wiring regulations BS7671
Hi, let me clarify a couple of points. On the continent we use the terms "Cable" and "Wire" Cable is 2 or more insulations and is multi core. Wire is just a single conductor "you call them Singles. As far as I know three is no requirement for singles to be used for power (it is a tradition) You can use conduit and run singles (UK method) or use cables in either trunking, trays or conduit. So, I am not worried about departure from 7671. It cannot be that using cables are allowed on the continent and not in the UK. Regulations are harmonised. I went through the same regs (your 7671) in Denmark 35 years ago. Scandinavia and Germany have the most advanced regs.
Again, my question is: what cable type (I emphasize, CABLE, not singles) is used let us say on a cable tray or ladder or clipped on wall for three phase installations in the UK. I will not be offended if you are unable to say, and I hope you will not be offended either as I have realised people in these forums can easily get upset and sometimes are very good at belittling others for their lack of knowledge, instead of being helpful. No disrespect my friends :-)
The type of cable would be SWA, the correct means of support for all cables is stated in BS7671.
I am well aware of the difference between wires and cables so patronising members really isn't necessary.
We don’t use flat cables for anything beyond domestic… maybe offices or whatever.
For true industrial settings, we can use metal or pvc trunking and conduit with singles… or we can use surface run steel wired armoured cable. There are other cables less mechanically protected such as NYY (need to check) which is just a thicker, stiffer plastic outer coating without metallic armour…. but generally, on tray, it would be SWA.
Older installations, you can still find power and lighting run in MICC which is an art form to work on.
