Hi,
First time post and hoping you guys can help. I have a rather sad looking, original 'City of Lincoln' lamp post in my garden that I am trying to renovate. There was never a bulb fitted since I moved in 8 years ago. Power originates from the garage and is routed via a timer then underground to the post and the circuit is live. The house (1950's) was rewired 5 years ago and a new consumer unit fitted, however the wiring in the garage (late 1970's) was tested but not renewed.
I've read that a outdoor lamp post must be fitted with a RCD so I'm wondering if the RCD in the new consumer unit is sufficient or if I should incorporate a RCD fused spur/socket in the garage leading out to the lamp post?
Thanks in advance.
A street light in a garden which is accessible to the public would require RCD protection according to Regulations but that doesn't really apply to yours but being a lighting circuit in a dwelling it would so either way it would apply albeit Regulations are not retrospective to existing installations which this is. First thing you need to do is have the circuit tested in it's entirety to ensure it is safe and then see if the existing control gear is still in situ or whether it has been converted. It is likely it originally had control gear for a SOX lamp ( low pressure sodium) which gave an orange light. As for the RCD it is likely to be in place upstream from the garage when it was rewired five years ago.
Thanks westwood 10, I appreciate the fast response. I'll get the system tested and go from there. Out of interest what is the meaning of 'control gear' in my situation? Thanks.
Control gear will be within the column normally behind the access door.
Interesting. There is no access door - the lamp post is one solid cast iron (?) column with the cable running up through the center & into the lantern. So I'm assuming if there was some kind of control gear it would have been located above the lamp at the very top of the lantern, either that or the post is so old (it looks it) it never had control gear.
Sounds like there is no control gear but a lighting column normally has some means of connection.
Hi,
Thanks in advance.
if circuit already on rcd, it's ok, no need extra. Make sure outdoor wiring sealed properly.
Does the post look somewhat like below? (First pic shows a pair sold a while ago through Christies auction house in Japan!)
If original it dates from around 1890!
View attachment 124739View attachment 124741
Thanks everyone for your comments - really appreciate the help. I'm having the circuit checked out next week so hopefully everything will be fine. BTW, the 2 photos of the lamp posts sold at auction are identical to the one in my garden apart from being in much better condition ha ha! There was a lot of corrosion which I've already dealt with and I'm manufacturing a few small bits of trim for the lantern. Also going with 'glass look' perspex to replace the orange perspex (!) that someone had previously fitted. I live only 17 miles from Lincoln so I'm guessing it was picked up cheaply when this type of lamp post was decommissioned. Thanks again. Great website.
Looks a bit like the one that was outside my house when I was a child (a very long time ago!) in which case it was probably originally a gas light (Is this now the wrong forum :-)) and that's why there's no hatch at the base to hold the control gear...
