HappyHippyDad
Supporter
I seem to be getting more and more plaster in my back boxes after the plasterer has plastered.
Does anyone use the back box covers? there seems to be a few different types. Could anyone recommend ones they have used, or even say which ones they have used and didn't like?
thanks.
I’ve used a scrap piece of torn up cardboard box in the past
Just tuck behind the screw lugs.
Or you could have a stern word with the plasterer.
If it wasn't for you, @James and @westward10 I don't think we'd get many replies. Everyone's gone!
A couple of plasterers I've used (privately for home) in the past have carefully taken out the excess before it sets. In a way I'm not too keen on this as they can easily take off too much and leave a gap round/behind the accessories.
The plasterers should clear the boxes out, but it just doesn't seem to happen, hence looking at alternatives.
I always went by the credence that I make sure my cables are neatly in the box so as not to get in the way of their tools, and in return they clear out the box.
Like LS (post #2) I use an odd bit of cardboard just trimmed to size and tucked in behind lugs.
Seems to keep majority of plaster out except for the 3.5 screw holes but maybe should carry a bit of blue tack or Plasticine to temp protect the holes.
I use them all the time now. Saves a ton of cleanup and stops sockets getting packed with plaster. I tried the cheap flimsy covers before and they kept popping out once the skim coat went on.Rigid reusable ones are way better.
Which do you use ? The only ones I've seen are Yoozybox, which looking at the website seem a good idea.
Could you send a link to the ones you use please?
Forgot to mention, an old hacksaw blade works well. Use the box for a guide, and it removes large lumps leaving a nice clean edge.
Wrap one end with plenty of tape as a handle.
That is a nice idea! The jab saw is always too course.
Another couple of things come to mind ...
1) I would rather be removing plaster than have all the sockets "recessed". I've had it more than one where the skim is thinner around the sockets - if you put a long straight edge on the wall, there's a gap for a few inches around all the accessory boxes (widest at the box, tapering off away from it.)
2) Dual accessory boxes. A number of times I've had plasterers not fill the bridge between the boxes - so when you try and tighten the accessories, soft ones bend, rigid ones might crack. So you have to leave the screws fairly loose in the middle.
And if they do fill it, see 1 above.
I'm not quite sure I understand point 1. Why would the skim be thinner around the sockets? Is this in relation to using some kind of box protector?
