littlespark
Staff member
Supporter
Patron
my daughter picked up a tumble dryer free from a workmate, and apart from being a bit scruffy…. It might be ok.
I’ve dismantled it, cleaned it and fished out a load of fluff from places where fluff shouldn’t be!
I want to test its operation, but the condenser won’t go back in the slot. I think it’s overheated and warped the plastic… stopping it from going all the way in.
A new condenser is about £60, but in the meantime, would cutting off the warped plastic enough so it fits in be ok? Just to test it, then buy the new condenser if it’s ok?
It will be fine to leave it.
“Leave it”? You mean it’ll be ok to cut off the warped plastic?
It will not slot in properly, so the rubber seals around the condenser don’t fit into where they need to be, and can’t refit the front panel.
If I cut down to the black rubber seen in the photo, it should fit in correctly and shouldn’t change how it works at all.
I was a little worried about the fluff being everywhere inside… especially round the heating element area… but it’s all clean now.
Quote A new condenser is about £60, but in the meantime, would cutting off the warped plastic enough so it fits in be ok? Just to test it, then buy the new condenser if it’s ok?
Cut it to make it fit for now as long as air is forced though it will be fine for now
If heat warped it then heat can unwarp it, judicious use of hot air gun and apply pressure
BUT
the condenser shouldn't have ever become so hot that it warped the plastic, to me that points to another issue -perhaps fan related, or maybe it was so clogged up there was insufficient air flow.
I have a Zanussi which is similar design,, the condenser did need hosing out from time to time. I recently changed the belt which meant a thorough clean out after many years, even so I couldn't see a situation where that amount of heat would be caused.
I thought it was overheating myself… but there is thermistors in the back. Small discs that pop open circuit if too much.
Maybe the plastic is just too soft… thin walls att the point of warping.
Maybe the previous person used it constantly?
I had the rear cover off, and there is a fan to blow the heat into the drum… and rotates as the drum does. Quite tight… I thought maybe bearings, but our own dryer is just as tight. Washing machines seem to spin more freely.
Whatever the reason. I’ll cut off the damage plastic and try it out. If there’s any sign of getting too hot, I’ll have another look.
