V
VoltzElectrical
I was chatting to my neighbour over a cup of tea today when he mentioned his wide had bought some fancy metal switches for the kitchen. He then went on to explain that when he took the faceplate off he found this, then promptly put it back on again!
I had a look, and it's weird. Does anyone know just what the hell that is in the back box? It doesn't look or feel like rust, more like hardened resin residue of some sorts.
Anyway, after a bit of a look around, I asked to look at the fuseboard because I wanted to know how to isolate the switch to replace the box. Located outside in a gas box! new meter, TN-S system but check out the size of the earth! looks like 2.5mm. I recommended he upgrade the main earth, and got a Ze reading of 1.16 ohms. Thought I'd check Zs at the switch, 2.72 ohms.
No bonding. Discussed this with him, gas is a right pain to get too, BEHIND kitchen units, water under sink.
Can you run bonding cables outside then make connections inside?
How would you upgrade consumer unit given the space?
I'd be tempted to do the bonding, upgrade the main earth and leave it the hell alone. After all it's worked for years. Failing that it's relocate the whole lot on the other side of the wall on the inside of the property with longer tails as I'lll never get a new board in that space.
Anyway, all thoughts welcome. The original question is What is THAT in the back box? Weird that.
Oh, and all I'm planning is isolating the switch, replacing the back box, lose the supply to the outside light (not needed) and tape up the nicked cable. For another cup of tea!
Cheers.
