Freezer all that distance away, sod that.
If you are doing the job and being paid per hour, and its PVC conduit, make sure you carefully glue each and every joint.
Stretch it out, then see what they have to say about the cost versus you putting SWA down!!
Your customer is going to have a Freezer 100 metres away from the house?? Well that makes a lot of sense then!!! lol!!!:shocked3: :lipsrsealed2:
So what's the depth has this PVC conduit been buried too?? You could to get a fair bit of condensation in that pipe, another problem with using conduit, especially over long distance with no openings and little or no means of air flow!!
