whats that a similar model boiler needsaspark
yes the same, only i used a honeywell stat
Live in 1, switchlive out of 3 to boiler with a neutral on 2
Well it worked fine on mine. from memory on the boiler it was live out of 3 and boiler trigger on 4 but that may be differnt on yours.
OK so what would the neutral do? I think its wrong.... i need opinions
It boils down to what the combi stat needs to function (is it a just a simple bi metalic type or electronic based). If the latter it would need either a neutral or battery power.
If the stat is switching the Boiler / Pump on off then to all intents & purposes it is working, the problem may be that it's out of spec on it's temperature range & could have been so from new. The only real way to find out is to replace the Stat.
Ok the only reason im posting this is that im concerned... i have a thermostat and am convinced its not right... posted here before advice get someone to look at it... im certain it reads too low.
After reading the first post, ​I just dont quite see what is the users problem
Just turn the stat up a few degrees or down a few degrees to compensate
The scale on anything including a stat is only relative to what you want it to be,compensate
But, but, but, it stops me getting bored :)
Got to the bottom of this... wrong stat on there... hence why it never worked properly... i had to phone manufacturers to get this info... one heating guy got it wrong and offered no help really to fix it... really annoyed! I basically did his job for him...
OlafIrolp,
OlafIrolp,
