For my benifit - What is an sfc ? as in "fuse the socket down with a sfc of its own so it cant pull more than 13amps"
switched fuse connection unit. should read SFCU. FCU is unswitched......
can anyone recommend a decent pir flood light? do they vary on their manual overide features? ie one will require a 3 core and one can be overide by switching spur on and off? thanks
timeguard are OK. don't buy b&q ones, they're crap. i generally use 3 core so that the manual override is certain, rather than messing about with that ON/OFF/ON/OFF rubbish.
Most that have an override will operate fine on a 2C+E, as long as you only want the PIR to operate when the switch is on (by default it'll timeout after a set time). Override to PIR is often turn on/off/on again (within about 5 secs).
Now i know you are old school, Tel.
Word for word what i was told when training, lol
growler,
needasparks,
