Rockingit
Mentor
Evening all,
just wondered if anyone knows where I can get some stupid-length (like 125mm+) M3.5's from. Someone decided to raise a floor by another 70mm odd but the boxes are set deep in the original depth screed. Prefer not to double-stack boxes if possible!
R.
longest ive used are 70mm i think,,,youll have to get a few of the extension pieces all screwed in together lol
I think i saw some in Selco today, didn't look that closely but i think they were about 125mm
Standard machine screws should be available off the shelf up to at least 100mm. For really long screws I've use extension nuts (sometimes called coupling nuts as well) and threaded rod in the past. When they're really long they become a pain to find the thread though.
Longest I have come across is 75MM. Could just use extension studs out from the back box though.
Go to your local machine shop( if you don't have a lathe) and get them to run you a length of threaded bar up and cut it to a length that will correspond to the adapter. better still do what Tel says.
surprised they aint concreted the boxes over. bloody muppets.
Extension studs are like these, but have the 3.5MM thread on them to screw into the box. If needs be you can just keep adding and adding them together
you could always chuck in a gob of expanding foam and stick a dry-lining box in.
I know the things you mean, we use exactly the same thing in nylon for PCB mounts. I haven't seen them in steel but I'll keep an eye out for them, they're very handy.
