Without being prepared to make the investment in tools and equipment then you are down to an educated guess and ripping the floor boards up
You are of correct there. No one really likes spending money but with things like that they are priceless when fault finding and on inspections. I bought my camera about 5yrs ago for £150 and its paid for itself more times over than i can remember.
I like the cable tracer idea. I have one that will work to locate cables buried up to 1 meter and you can adjust the sensitivity etc. I'm sure it would work at least up to the transformer.
Going by how the roads sink after cables have been run I think that's what they use with about 10mm of tarmac over the top.
Now you have said that, I may be thinking of something completely different like one of them light pen things.
OK, I'll get my coat !!!!!!
Drop all the fittings put the remote unit on each of the cables and trace it back all cables will / should merge at one point the transformer. You could try a stethoscope on the ceiling and listen for the transformer hum
is it serious doc??
no sir you just have a bad case of transformer hum.i'll give you a good whack on the back that should sort it.:ihih:
