ipf
Mentor
Had a replacement to do in a works, new fitting on site but it's the last one available. Loads of 8fts in use in the building, most fitted on lighting trunking or conduit systems. Future replacements will, obviously, have to be 6ft. It's been bugging me for a while now, why they don't make a 6ft with 4ft centres?
I'm clearly out of touch. Have 8ft tubes and fittings been discontinued? If so, does anyone know why? (Not that I like them, a bit awkward to install working alone.)
discontinued as they were not very energy saving!!
job im on at present we have just ripped 10 or so down from roof!
There's about 300 in this place. The irony is, we installed 'em all (over the last 35 years or so)
can you not just repair the fittings that are up in place..!!
Not looked into that yet DS. Not many gone down but most of them are getting on a bit. May be worth looking into but I think there may be probs getting the correct ballasts and prices if available. Interesting though. Cost effectiveness is the thing that springs to mind.
Cost effectiveness = LED TUBE!!!
no ballast , no starter, no bits and pieces, direct voltage 4 year life span!! all for a £60 tube!
There is a twin 4ft kit you can get that comes with a linking kit and centre support that is a replacment for the eight foot tube.
I had not heard of it until i went to one of my clients who was approached but a company that supplies and changes them for you.
They have about a hundred 8ft fittings and with these new tubes can save about 25% on the usage as they are T5.
Not sure where to get the kit yet or how much it costs and obviously the light output is not the same but as triphosphor the light is a bit whiter.
Don't seem too bad if you have a load of fittings and don't want to change to 6ft.
Anyone else come across these yet.
Not seen that one yet but tried a 6ft with an extension. It was the works managing directors idea. What a load of c***. First one broke assembling it, second has been in for a couple of months. It sags at the joint and has to be nudged, usually with a sweeping brush, to get it started. £20 plus, too.
Don't think this was the same company but there are quite a few if you google that do conversions now and they are registered with the carbon trust so the client can get a grant to pay some of it if they run a lot in a office/factory etc.
I think more are springing up since the new electrical usage levy is hiiting a lot of commercial customers now and have had there bills doubled with it.
adapT5 - T5 RETROFIT CONVERSION KITS
We had the same experience with them, had a company in that fitted them as a trial, have since taken them down and replaced with 6ft fittings.
ipf,
grantr37,
