I
i=p/u
was woking with panel today that these circuit breakers
http://www.mebamfg.com/pdf/NF250-CS-Moulded-Case-Circuit-Breaker.pdf
can you use one side as a live feed to another circuit breaker
what is bs numbers for these circuit breakers is it bs 4752
you can set the I (amps) with a dial and there is a red button to test the thermal magnetic disconnection
big board than normal for me
