R
what you are describing is a so called lollipop ring, these are not prevented by the regulations but can be a nightmare to identify later.
So is this what used to be done? 4mm to jb then Ring from there?
I was always under the impression that this was frowned upon?
Generally, yes frowned upon but not dangerous or against the regs, just inconvenient to test and check later. I do not think it was ever standard, (but I could be wrong)what you are describing is a so called lollipop ring, these are not prevented by the regulations but can be a nightmare to identify later.
