I
i=p/u
kitchen /dinning room , id be tempted to go for warm white fire rated fitting with led bulb in what price roughly are you getting these fittings for and if money wasnt the question would you just go for the full jcc fitting...
Depends on the décor of the room and the customers choice
I personally prefer the brighter 'cool' light for bathrooms and kitchens
JCC fittings come with a 10 year warranty, use push fit loop in and out connections and look great.
I've fitted quite a few recently, but each time I let the client buy them directly from the wholesaler.
would it look funny with cool white in kitchen, then warm white in dinning/living room which is open plan
and would you know roughly what price they getting them for??? ive fittem them too in a hotel and they were great apart from you need to use <1mm flex
Halers Evolveled around £35-£40 depending on dimmable or not 7 year warranty Iv seen the Hotel chain I work in had cheap alternative LED lamps put in and 6 months later they are starting to flicker and pop out specialy when they are on 24/7
had enough for lighting, but thanks guys need to do quote for tomorrow evening, so im doing standard fire rated downlights and pendants everywhere else as havent seen the house and haavent spoke to woman in question....
standard fittings is what she getting quoted for then if she asks about cromes sockets and lighting with led' sshe;l have to give me £100 to explain it all to her...
the builder just wants a quote so thats what hel get.... i dont get some people, or am i too passionate about all this
ps if there is a wood burning stoove in living room would you use smoke or heat detector, id say heat, there is open plan bedroom upstairs which looks over the stove with railing would a smoke detector be need up there ...???? even tho no walls and you would hear it
Building regs would require a carbon monoxide and heat detector in a room with a log fire.
can the carbon minoxide be battery powered, would they link into heat detectors???
also have you ever seen the shower room lights with vent built in, do they require a perm live aswell as switched live ??? cheers tb
The carbon monoxide detector does not have to be connected to the smoke/heat detector circuit.
The heat detector would be required in your case because it is open plan with the 1st floor.
We had the same situation recently, the local council stipulated these requirements.
Take it you mean a bathroom light with a combined extractor fan.
It would need a permanent supply to give timer overrun.
i=p/u,
mogga,
