How much are the 12v spots costing to buy? I don't know if its surprisingly cheap, or surprisingly expensive.
Getting spots for about £10 each? They are not cheapest but decent quality. I find you get crap with cheap.
IS there a particular reason your using 12v instead of 240v?
My price was around £875 btw.
And then there is always that return visit because the kitchen fitter was not as far finished as he thought he would be or one unit did not arrive or was damaged
i once had to drive 25 miles because an under cabinet light stopped working(which the kitchen suppliers supplied) after the kitchen fitter took the cabinet off the wall after i had gone. Turned out to be the lamp had shaken out of the holder. All for free!
I think that if you get called out due to a fault which has nothing to do with your workmanship, then a call-out fee is in order. Make it clear at the start tho.
Having to add RCD enclosure to protect sockets as original board has no RCD and not one available.
It always amazes me, homeowners prepared to throw literary thousands upon thousands at new kitchens, but are more than happy to leave an old CU with old OCPD protecting the whole house!! How much would it be, to change that CU to the latest best specification. When all said and done, the electrical installation (especially the CU) will still be there and working, way after this new kitchen has long been forgotten!! lol!!
Just been to look at one today - £8K + kitchen, terrible electrics, would they spend £500 - now waiting to hear!
It's not that old it has new mcb's but no front end rcd, rcbo is available but at £50 not worth it when enclosure is £25? Also could it be possible to add an enclosure with an 30mA to protect the whole
Installation, so in essence rcd as main switch?
Yeah thought as much can't remember where about in the regs it is but i knew it was there!!
Great stuff! I chose 12v downlights as i was going for more energy efficient but when i come to think of it what are the benefits of using 12v as opposed to 240v ?? or vice versa?
What makes you think 12v lights are more energy efficient?
230v LED's will be the most energy efficient mate. 12v if you need the ELV safety factor.
How do you figure that? 50 watts, is 50 watts.
I reckon for around £10 cost price I could get GU10 fitting and good LED lamps - much more energy efficient.
12v with the transformers use more power!,my local wholesalers were doing led fittings for £40 each,so maybe £200 more expensive on outlay,but the benefits in the future of not needing to keep replacing halogen lamps and transformers when they give up will have paid for itself within 10 years if not earlier,not to mention the kwh saving over the years.although as already mentioned people would rather spend ££££s on kitchen units then bother too much with the electrics.
