I
i=p/u
when using wago's for downlight guys many cables can actualy fit in the wagobox?
also a guy i worked with said you should loop the ciruit , but what stops you from going all directions, if have lots of lights??/?
Are you talking about the new WAGOLITE box or the standard WAGOBOX?
I assume you are talking about having a "spider" lighting circuit as opposed to a radial?
sure can can 4 5way wagos fit into a wagobox,
the line enclosures look very small but are a little cheaper.
also fellow sparky, do you have to loop your downlights one to the next one or can you go in few directions , i.e one going left, one going right , one going another way, any better
well, being a dinosaur, i loop from light to light, using an ashley 2" 4 terminal JB at each, with about 1ft. of H/R flex to the downlight.
im wiring to first junction box t&e then H/R flex through out and use wagos and hopefully fly through them.
Glad I'm not the only one. I did buy some wagos the other day tho... Let see if I use them. So far I've only used 2 to extend a circuit in a CU
well i plan too just use them as junction boxes as ive broken the lighten circuits up in a weird but fantastic way ... and just loop the light using junction box upon light.. that way il save a lot of jbs..
im still fishing and learning
If you go on Wagobox website there is a nice printable chart showing all the configurations you can fit into a box, along with descriptions. Print it in colour and laminate it for that great "nerdy" feeling. :cool:
they sent me one out when i blagged a free sample box one time but i give to college as i said i would.. on me way
I have a growing folder of various laminated (Nerdy), reference sheets. The Part P Assessor spotted it last time and got very excited with himself!
its all very well buyin em.......i was advised from a well known forum member that if i am ever back at the elex show....and i go past the wago jar....i should grab a large fistfull......
