S
SKY
Hi All
In a small factory I do work in operators are complaining of getting static shocks from a stainless table.
I have put it down to persons building up a charge and it discharging when they touch the table.
It gets me thinking that does a small stainless steel table require bonding?
NO!! the old system of bonding S/Steel tables in commercial kitchens (15th edition i think) has long since discarded!!
Cheaper to change the table for a non metallic table!! Bonded metalwork does not stop static shocks, if anything it will exasperate them.... Very difficult to totally eradicate static build-up when it's present, almost a Science on it's own!! lol!!
fit the operators with static tails.
I remember seeing something designed to cure this. Little rectangular pad which you stuck to the corner of tables/filing cabinets, etc. which was resistive. Basically you touch this pad as you get to the table before you start work and it discharges the static charge in a controlled manner. Daz
I second fixed a kitchen last week with metal face plates, kitchen fitter had just laid laminate floor, unwrapped from its plastic cover, every time i walked across the floor and touched an outlet or switch i got a shock. I was wearing rubber soled shoes so was obviously charging up walking across floor. The owner tried it and nothing.
Well, keep jumpin' Jax.lol.
could you put some rubber feet on the table legs to isolate it from the earth thus eliminating the return path for the static?
should a senior member need to ask such a question!!!! if you earthed it were would you earth it from and too
