BT owns the stuff up to the master socket, i.e. from pole or underground, into the house and terminated on a socket usually marked with BT. After that point then you can run additional sockets using cat 3 or 5 to secondary sockets which have no internal components. You can convert a master to secondary by removing the ringing capacitor, line resistor and surge protector. you connect cables 2,3 and 5 together preferably using the std colours of 2(blue/white) , 3(orange/white) and 5(white/blue). Always best to leave the master where it is and run secondaries around the house simply daisy chaining the remembering that more than 5 phones and you may have trouble getting them to ring, also if its a broadband line you need a filter with every phone/fax connected, hope this helps
P&S - ex BT
What style of master socket is it? If it's an NTE5 (with a removable lower faceplate) you're in luck. BT helpfully provide four crone terminals on the back of the faceplate to wire extensions to. If not, then a plug-in extension kit or something might have to do. The master sockets are an integral part of BT's network and they get upset when they find people messing with them.
P&S - ex BT
If you want your ADSL interference free and good broadband speed don't connect terminal 3
If your broadband router is at the master socket then use one of these BT NTE-2000 ADSL Faceplate for NTE5 to replace the lower half of the master and you don't need filters on the slave sockets
