O
Octopus
Ok, I've put my tin hat on and I'm interested to know how other in the arms interpret the word "assessible"
Is under a carpet, and under screwed or nailed down floorboards "accessible"??
I think not.
Maybe I need to get into my bunker!
If it is where you might expect it to be, ie. in a loft under some insulation, then it is accessible. If you have to remove ceilings/floorboards/carpets/walls then it is only accessible if clearly marked on the outside.
In other words, if you have to be sherlock holmes to find it, regardless of whether it is under a hatch, then it aint accessible in my eyes.
Just my take.
I think not.
I assume you mean "accessible"
I think the term will mean different things to everyone to me it's accessible if you don't have to destroy something to get to it. I don't see moving a floorboard unless it's tiled over a problem to access something. These days with solid board cutters and covers and the routabout system it makes it very easy to make something more accessible
If it can't be under a floorboard for you then I can only assume it needs to be an in your face architectural feature
To my mind carpet and floorboards is assessable. Floor sheeting buried under laminate or tiles isn’t.
But you can put a JB under a floor, who knows what the householder will do in the future?
Come on it’s common sense and what the situation is at the present moment.
No one can give a definitive answer.
Agree Tony, most of what we do is common sense and experience, hence the worries we all have about the "quick" apprenticeships which are all the craze now.
Fortunately, with the new MF enclosures now available, if there is any concern we now have the answer.
Quite agree about the MF type units BUT its the old style ones with screws being used I don't like to see being used.
Look at it this way... personally, I hate JB's under floorboards, but think how much work they generate for us.... :sweatdrop:
The ideal solution would be to have a log attached to the CU that's updated whenever work's done. Put a JB wherever you want as long as it's listed on the log it's no problem to anyone.
Stuff like :-
JB under landing floorboards to take spur into spare room from upstairs ring.
10mm shower cable into loft continued as 6mm from isolator.
New downlights in kitchen wired as a 'spider' with JB above ceiling between downlight and back door.
It'd take a minute tops to make the note, and save some poor soul hours at a later date. No one will want to bother though, the "Why should I do someone else a favour?" mentality is too strong.
Stuff like :-
A god idea, however given the amount of new CU's I see without labelling for the MCB's I can't see many people doing this.
Stuff like :-
I think that is a brilliant idea. Unfortunately, lots of people are lazy, and the ones who aren't just wouldn't want to admit they placed a JB somewhere that may be construed as "inaccessible".
Always amazed me that the IET did the cop out and never actually defined the word "accessible" in section 2.
So really what is one mans/womans idea of accessible is not another, just makes our work that much easier, especially on EICRs, just to make it even murkier, the ESC/NICEIC "guide" also doesn't touch the subject either.
Same as the term "reasonably practicable". Everyone can interpret it their own way.
They sort of though had an half hearted attempt of defining accessible in reg 701.32.1 (which was a typ lol) and the zone under a bath, and the use of accessible and the use of a tool.
I can't see why they could not extend that to connections really, if you need to use a tool to access, then it should be classed as normally inaccessible.
Beat me 2 it Iv seen lighting installed in a commercial building then a few year later change in lay out makes the maintanaability of the lights almost impossible unless you hire one of those spider type boom lifts IMO its not "reasonably practical and said lighting should have been moved BUT in the opinion of the architect "you can get machines to reach it so its ok"
