I can't see why they could not extend that to connections really, if you need to use a tool to access, then it should be classed as normally inaccessible.
But that's the oddity with JBs. The only people accessing them, or doing anything to/with them must be 'competent'. Part of competency is have the correct equipment to work on the circuit. Therefore no one without tools should be accessing them. So in a way, JBs should only be accessible with tools.
They sort of though had an half hearted attempt of defining accessible in reg 701.32.1 (which was a typ lol) and the zone under a bath, and the use of accessible and the use of a tool.
I think that would be a great definition to sum-up the requirement.
"If access to an enclosure requires the use of a tool, it shall be deemed "inaccessible" unless the access to that enclosure is designed to be removed for maintenance purposes"
So what purposes other than maintenance would anyone want access to a JB for?
It'd take a minute tops to make the note, and save some poor soul hours at a later date. No one will want to bother though, the "Why should I do someone else a favour?" mentality is too strong.
This is a interesting point in it's own right: Personally, wherever I install something I'm always thinking about the bloke that follows me in fifteen years time and has to update/repair/whatever. We often swear at the previous 'electrician' for making life as hard as possible for us now, so why follow suit?
When I diversed into rock and roll touring all those years ago after I'd done my apprenticeship, one of my earliest mentors drummed it into me that 'before you put it in, you think about how you'll get it out again' because that's the way of touring - off the truck, build, show, back on the truck as quick as possible, drink beer.
I should imagine touring with a rock band that applies to more than electrical connections!
I couldn't possibly comment. :censored:
Exactly!! A floorboard isn't designed to be lifted for maintenance purposes, therefore the JB would be "inaccessible". A bath panel is designed to be removed (with or without the use of a tool), so the JB is "accessible".
Coming from an electrical engineering background, I spent 20+ years making sure that I could get access to everything I did, as it was always myself or a workmate who would have to work on it next. I now approach every job with this mindset, much to the annoyance of builders/plasterers who complain that all my concealed cabling is in oval conduit....
Sorry, I disagree. Lifting a floorboard isn't difficult or unreasonable to do, likewise lifting carpet to access the floorboard. Removing laminate floors, tiles, and chipboard panels on floors, or tiles and plaster on was would render the JB inaccessible as they cannot be removed and replaced without causing damage.
My personal view (and interpetation of the guidance) is that if a JB (or anything else for that matter) can be accessed by removing something which can be replaced without causing any damage then it's accessible. Tools don't enter into the consideration for a professional/tradesman.
Apart from when you consider that the terms for a PIR/EICR is that you are inspecting what is accessible WITHOUT use of tools. If you take that line to it's logical conclusion, then ANYTHING is accessible with the right size sledgehammer just so long as you're pro in using it. With MF kit so readily available, why bother trying to defend when a set of brass screws is/isn't going to be dug up again?
I'd agree with imago, having to use a tool isn't the issue here. So the definition above is a good one. But it's no good having a removable panel if you don't know that it's there. For example, I was trying to trace a ground floor lighting fault. Had the bedroom carpet pulled back and was cutting out floorboards to see which way the cable went. Eventually discovered a small section of floorboard held down by a couple of screws with a junction box screwed to the joist below. It was clearly part of the original installation, but very neatly done and with no markings, so very hard to spot.
A floorplan with every electrical accessory and junction box marked would be ideal, but who's going to pay to have it done as thoroughly as that.
Basically, anyone who regularly buries JB's under floorboards will defend that it's fine. I appreciate that it is done when no other practical option is available, but I wouldn't defend it as "accessible". Besides, how many boards can you honestly say can be removed without some damage, however small? Have to agree to disagree here...
Moot point now anyway with the new MF systems from line et al.
"My personal view (and interpetation of the guidance) is that if a JB (or anything else for that matter) can be accessed by removing something which can be replaced without causing any damage then it's accessible."
So using a sledge hammer doesn't apply now does it. I'm not defending anything, simply expressing an opinion and describing how I interpret access. Guidance notes are, unsurprisingly, for guidance not blind obedience. There is no way that anyone can make a definative statement like 'anything under a floorboard is inaccessible'. Therefore I use my judgement, common sense and experience on the situation in front of me on the day.
Which brings us back to my earlier post, where anyone working on the installation would make a brief note attached to the CU. No cost involved, no impact on job time. As I and others said though, it won't happen because 90% of electricians/plumbers can't be bothered as it doesn't benefit them.
