O
Oli
OK Chaps,
Not a sparky, just pop over from tilers forums to help out, albeit very little as the mods here are great.
Just need a bit of advice,
Moved to a new build house, have a security light above the front door in a recess which is switched inside the house and activated by a built in movement sensor, I want another one round the back and maybe one at the side too, can these be wired into the existing one
What would i expect to pay if i supply the lights, i'd not really be bothered whether they all came on when any of the sensors went off or if they worked individually, the missus just doesnt want any holes making in the walls, so wiring into the existing one seems the ideal option... assuming its possible.
Cheers
Oli
At a guess, probably a days work plus some materials, so approx 180 - 200 squids.
I could be over estimating.
My telepathy skills are not good this evening as i cant see that far to your house from here :D
i would say if you bought the lights and flex is clipped to the outside wall as it would look nicer you could have it done for about £100 with test cert and it would take a proffesional only a couple of hours start to finish
