B
bartkusal
Hello everyone,
I need some light on some issues ,and hope you guys can help me,I'll try to be short...
This afternoon i am going to have a look at three flats which needs a rewire, and potentialy start next week, so I need to grasp a couple of things before I get there. It is council flats,everything is ready to be started, they want all circuits surface mounted ( I know horible,not my cup of tee, but thats what they want, and I have no intentions to argue,in fact it only will be easier for me).
I have to say the job will be used for my assesment with NIC, so no mistakes here. I have extencive experience with house rewires for the company and cormftable with everything, but I start on my own and I never done flats, especialy council ones. So potentialy I hope you can advice what to expect from the job, and what assesor may be picky on.
The main thing which concerns me is the main incoming supply. I know by the latest regs we have to install minimum 25mm2 meter tails, 16mm2 main earthing and 10mm2 main protective bonding to water and gas. What I am trying to make sence of is, if the supply cable to meter have only 16mm2, so what is the point to increase it to 25mm2 after meter, its not like the supply cable is to small for the load, and dont realy need increasing for this mater, but I cant find enywhere in the regs is there is a requiment for it to be 25mm2, and if there is, who is responcible, I suppose its not DNO as the suply will end at the main cutout in the basement and feed to flats are just submains distribution circuits, so if there is the requirements to change to 25mm2, who has to do it, and how to go about it.
Aswell as this, if you have any issues I should be aware of, please let me know.
I am very gratfull in advance for your time and advice, most apreciated.
regards: Al
regards: Al
