I
imago
I don't think it is, but then I started to wonder. I have some work to do in a bathroom (domestic) all of which is 'like for like' except for the shower circuit. Currently fitted eledctric shower is to be disconnected. It's an 8.5kW wired in 10mm to and from the isolator, everything OK on that score as 6mm would be fine with the run as is. The shower is coming out and they're having a mixer fitted so they want the shower cable disconnecting. As it will be less disruptive and may be handy in future if the cable remains in place, they want it capped (I will also labell it at CU, old isolator position above ceiling and in the stud wall).
I then started to wonder if this is notifyable? That and the other bits will get a MWC, but I started to get a niggling doubt about notifying the disconnect as the cable's remaining in place so if you were being pedantic the circuit is still in place, but altered.
I'm just over-thinking this aren't I?
Is it worth the hassle of the over-think for the sake of £1.50?
If you are doing a reasonable amount of work in a bathroom I would tend to notify anyway, just in case.
If I was disconnecting a shower and disconnecting the cable at both ends then I would not notify as this is removal and is not covered in regs.
Not notifyable imho, its like for like (I assume light fittings) and the disconnection of a redundant circuit. As you've said just note it on/near the c/u for the next sparky.
Cheers for your thoughts gents.
Other than the disconnect, it's swapping the baton fitting for a 'nicer' light and changing the pull switch. Testing wise, I'll check the first floor lighting circuit, earthing and bonding (visual done and all looks fine).
I think I'll err on the side of caution, as Rockingit say for the sake of £1:50. I can check the IR of the cable run before I cap it as it'll be off anyway. It's an odd one really as the circuit will still exist, and I will have altered it therefore it should be notified. On the other hand, it's not a circuit in use so it shouldn't count.
i wouldn't even notify that to my dog. disconnect the supply end of the cable, then it's no longer a circuit, just a piece of redundant cable. if it's not a circuit anymore, it's not part of the installation, therefore what would you notify it as? suppose you could notify the pikeys.
In no particular order the reasons for are:-
1) Instil in a customer the idea of having work done by a registered sparky.
2) There is a circuit in place which can be used.
3) I pay ELECSA a considerable sum each year so they can earn it.
4) As number 3, but for BC.
5) Raise a debate/arguement on the forum.
6) Why not?
7) Another bit of paper in circulation with my company name on it.
8) Makes the customer think they're getting their money's worth.
9) Draws attention to the fact that it was disconnected properly.
10) Makes damn sure that no matter which fool messes about with it in future I can demonstrate it was safe when I left it.
Reasons against doing it:-
1) It costs £1:50.
2) It's not strictly required.
3) No one truely gives a monkey's about Part 'P' and the snowstorm of paperwork it generates.
imago,your reasons against list missed out the fundamental and possibly only reason for all notifications
The notification procedure exists only as a streetmap for the inland revenue to target legitimate sparks, instead of the army of individuals who work under the radar
True Des, very true, and given that it is I'm inclined to go with the 'squeaky clean' approach.
"Look, you can clearly see I declare everything and don't work for cash. There's no cash deposits into my personal or business accounts, and I even notify very small jobs. So you can roll up your audit paperwork, take a good run up and shove it right up ....."
I know this was touched upon in a thread a while back, but, really?? Are we THAT suspicious and willing to side with the conspiracy theorists? I think this is giving them a credit where none is due, frankly.
I don't think that was the reason for the introduction of the notification thing but someone in HMRC must have looked at it and said "Cracking idea guys, now we can use that to clamp down on them" I think it's only a matter of time before it's extended to cover other aspects of our industry
