E
ed-ectrician
a helper as two brains are better than one sometimes....
Especially with my brain haha!
Scrape the last few CMs of the spare ends with your snips/knife then write on them what circuit it isI/PU: don't use tape for marking cables unless you have nothing else.
Cheers all! Got most of the things you all suggested too actually, my list was a bit crap! - had a few jars it's sat night and spurs won today for once!
My mains SDS and (for lighter stuff) 18v SDS with chisel bits are ok for chasing surely? What do you all mean by chaser? I always used sds with chisel for chasing. Some use angle grinder and bolster chisel. Bash it up with a sds chisel bit surely?!
Do i need a separate core cutter by the way? Can I use a 800w £100 hitachi 230v jobby with diamond core bit for extractor fans etc?!
Ed
i mean identifying switch wires when you normal t&e brown and blue, do you mean this do , cos me not understand!
Twin brown for switches man, it's the way forward! The futureWhen doing loop in loop out at ceiling rose put a nick in the switch t+e, the other two therefore must be the feed in and out. I use brown as perm live to switch and blue with brown sleve as switch live. I sure you knew that already but it may help others out.
