M
monkee
Hi please help i have gone looking for the calculation on watts per hour and the costs but it all seems a bit long winded,
lets keep it simple 60 watt lamp GLS left on for 8 hours are will billed in hours although we are using units also do we convert the lamp in to hours then how do i work out what i am being
charged
some helpfull tips would be great
Your electricity supplier charges you in Kw per hour (ie 1000w)
So if you had 10 100w lamps on for 1 hour that would be that kw
HI so does my bill get rounded down say if i have used 2 hours and fiftheen minutes?
or do thay say 2.25 kw used is it 10 pence per kwatt used = £2.35
60w lamp for 8 hrs= 480w
or in suppliers units 0.48kw
so say at £1 per kw (may be that sooon) = 48p
They'll charge to the nearest penny.
KWHr is a measure of quantity not time. If you use 1 KWHr in 26 minuets, you will have used 2.3 KWHr in an hour.
Pity it isn’t as you think, I’d have everything on timers so they shut off a couple of minuets an hour.
exactly
or for instance, a 1000 watt heater switched on for 1 hour uses 1kwh (1 kilo watt hour) if the electricity price is say-15 pence for 1kwh then the heater has cost you 15 pence for an hours use
And a 60w lamp running for 60min has cost the same as a 30w lamp running for 30min etc etc etc
Take the wattage of the item: (W)
The time it is on in hours (or the minutes it is on divided by 60): (t)
(W/1000)*t = kWh
So for 60W lamp for 8 hours
(60/1000)*8 = 0.48kWh
100W lamp for 10min
(100/1000) * (10/60) =0.017kWh
2400W (2.4kW) oven for 1.5 hours
(2.4) *1.5 = 3.6kWh
once you have kWh multiply by your cost per unit (kWh) and get the cost of running that item for that time.
Richard thanks for the time to show us the calculation
to keep it simple lets say the cost 20p per unit used so the 2.4 kw cooker is on for 1.5 = 3.6
so 3.6 * .20 =0.72
£0.72
i tried 6watt @ 4 hours
(6/1000)*4=0.006
0.006*.20=0.0012
less than a peny your thoughts please
so 3.6 * .20 =0.72
£0.72 correct
(6/1000)*4= 0.006*4 = 0.024kWh
0.006*.20=0.0012
0.024* 0.20p = 0.048p
less than a penny your thoughts please
see changes above
