Resu
Mentor
What do you guys use for glanding SWA and what would you recommend a budding young (skint) apprentice buys because he's fed up of the pin falling out his cheap Silverline waterpump pliers (I've tried to fix them!).
One of these...
You only need a screwdriver.
250mm Ck adjustables , never use anything else , 3 sets have lasted my entire career.
nuff said.
bahco ones about 20 pounds, ones in your local tool shops for about £10 might be ok....maplins sell ones for about £5
Banco or knipex cobra had a set of each for years still going strong
Sent from my iPad using Tapatalk
I use water pump pliers ck 250mm and 210mm find the 210mm most convenient to be honest. CKs are very good but barco v.good as well
You can check out the whole bahco range on the website wwwDOTbahcoDOTcom follow Products / Catalogue on the digital catalogue choose english and then page 594 in the top of the frame
Hope this helps
For the awkward ones get yourself a basin wrench, the sort with two sizes of grip that can be swapped over.
i never goth a pair. what do sparks use waterpump pliers for? tightening swa glads yeah I know :)
emergency pipe repair when you cut one with a chaser :)
not many uses in domestic world.
