S
South Spark
Looked at a premises today with a secondary consumer unit upstairs run off a 40A breaker on the main board.
The cable feeding the secondary consumer unit is a type I haven't seen before - two seperate insulated cables inside what looks like a solid copper sheath. There's an earth clamp on the copper sheath bonded back to main earth.
Any ideas?
Is there any reason why MICC would have been used in a straight run in a domestic premises? - It's RCD protected so no need for it even to be SWA.
firstly it will have been installed way before rcds were even invented.
and it can carry more current than its equivolent pvc counterpart.
Lovely stuff, apparently it can be run over by a steam roller and still work, well thats what they told us years ago when it was used everywhere on county council schools and premises, I still got my pyro kit now, it's probably a bit rusty now though, I still have some 3L1 as well in the shed.
Lovely stuff, apparently it can be run over by a steam roller and still work, well that's what they told us years ago when it was used everywhere on county council schools and premises, I still got my pyro kit now, it's probably a bit rusty now though, I still have some 3L1 as well in the shed.
I can remember seeing that promotional video, think in conjunction with Edinburgh University. As i remember a light was being supplied by the MICC cable while the steamroller passed over it 12 or 3 times. Think they had posters showing the same thing too...
Got any pictures of how pyro should be terminated ? Cos this one don't look too pretty.
There should be a gland on it first then a brass pot was threaded on to the outer sheath and filled with potting compound and a lid crimped on with the wires coming out through the lid they would then be sleeved marked and terminated. Normally tested at each stage because they could be hard to terminated correctly if you were not up to it but have to say I loved the stuff.
Try google micc cable you will see the termination and the tools used but I used to be able to do them with junior hacksaw , side cutters and pipe grips when we were short of the proper tools lol. I am sure many would use the same when stuck.
In the older days we used heat shrinks on pyros as well, I actually liked these, but they outlawed them, very handy for pyros in plastic trunking in schools where terminations into breakglasses were needed, of course pots with an earth welded to the side replaced them and the breakglass boxes had a cable grip inside for them, very neat, would nead to see a picture of your pyro to confirm what has happened to it and whether the end is okay or a rough Job fella.
South Spark,
telectrix,
