probably, but not necessarily, think 2 lights in a room, and feeds to switches, a real possibility
was working but not switching, using my super powers (acquired though years of college and work !!! haha) i recon he has the live feed in with the brown and he's sending the neutral down to the switch by having both blacks together hence the fitting just getting a feed live and a neutral, so it works but doesn't switch.
I could be wrong........
(not usually lol)
Learning to understand is the first step. If you don't understand, get someone who does. Going in blindfold, as you obviously have done, can be very dangerous.
OP, I admire your willingness to have a go but electricity is not something that the uninitiated should be messing with. The generally accepted lethal current is measured in thousandths of amperes and the circuit you are proposing to work on is most likely protected by a 5 or 6 amp protective device. This may disconnect in milliseconds or it may not, there is no way of knowing. Furthermore, mistakes are easily made. Those mistakes can and often do result in harmful or even fatal shock to others (your loved ones) or fires which would not only destroy your home but most likely your family life too.
For what this job would cost, is it not worth getting a suitably qualified person in to fit this/these light(s) for you which would give you peace of mind that the job had been done correctly?
Some of the guys are taking the mick not because they want to belittle you but because we often see what we call joke threads ie something posted up by one who knows what he is doing but also that a basic question will wind a lot of us up.
(not usually lol)
there is 2 possible senarios, the usual feed/ neutral in and pair to the switch and a long shot but not unheard of switch pair in and out to another light, if you look at the picture again there is another pendant on the top right of the picture, remote admittedly, but still a chance it could be connected to this light, hence my suggestion he calls a spark in, for me and you it is so simple we could sort it out in seconds, but he could be killed, I understand what your saying, just saying about a remote situation myself.
OK guys, im happy to say I did it last night,
here is a picture of the original: SORRY I then realized that would have been a good idea, its funny because everyone on here seems to jump and bite when I clearly said in the beguining I have no proper knowledge or terminology I specialize in finance not electrics but I like to do my own person DIY and mechanics which I find is simple if following guides....
anyway here is the pic of the wiring before:
and after watching about 2 hours of YOUTUBE and a further few forums here is the end result :D
end product :)
thanks for a few peoples input on here I understood it, finding out the live took some time but all done eventually, as long as you use common sense and respect safety and have a passion for doing your own DIY then it seems to nicely work out plus it helped me understand a lot about my other lights :) - was simple though not as special as some people made...
and i hope you taped up that connector block as well....just to give the cables a bit of support..and for a bit of insulation as well...
great idea actually, I didnt do it but will do it thanks :)
where did you get the brown sleaving for the switch wire from ?
my tool box, was from an old spare wire, I cut it and took the metal wires from the inside as I wanted to match it with the brown wire under it
thanks :) I know its basics for u guys but I really like doing stuff myself especially that I've just got my own place
Thanks for the update and well done, may I just ask how you proved which of the black cores was the switch live and which was the neutral conductor?
thanks mate and yeah of course, I literally just plugged it in and it worked when I switched the mains on, then the switch on and off, had it not worked I would have swapped them around
Sorry to say you may still have switch live and neutral the wrong way around unless you prove the switch live with a MFT. It works either way but you may have it back to front, I am not being padantic but I would rather it was correct for your own safety mate.
i was going to ask what are the consequences of getting it mixed up if I did have it mixed up?
