S
Stuuk1
Well, chases actually..
I have a load of chases for fill at my house including parts of the wall that fell apart etc.
I read so many different view on the Internet from various forums.. So went to b&q tonight and got the following:
Bonding Coat
Multi Finish
Ready Mix Cement
My plan is to fill the chases up with Bonding Coat and scrape a little out of each one and then once dry fill that 3-4mm space with the Multi-Finish?
The cement I will use around each box to fill those gaps etc.
Is that what anyway would recommend? I just don't wanna anything to crack!
get some PVA in some water first wont you....get the edges of them chases prepped n bonded with that stuff......or you`l find yoursen chasin yoursen round the wall with your filling.......
Sorry forgot to mention, I have already given them a first coat of pva/water and will go over them again before I bond them.
Should I wait for the second coat of pva to fully dry or apply the bonding when its 'tacky' as I read somewhere...?
Are these chases for electrical installations or are you the new fred west?
Only joking buddy ( i said that in relation to your thread title )
If the full walls gone you may aswell do a full re-plaster. I just use ready-mix solutions though aye, or if theres a plasterer on site, palm the job off to him for no-pay because us electricians are ruthless haha!
let the second PVA tack.....then get your fill on......leave it shaller for a toppin wont you...
aye...if its blown then belt it all off with an ammer.....bond and topping...(thistle)....
it's friday glenn. you should be on your 3rd pint.
Thanks for the advise chaps,
Ill get on with this job tomorrow... I wish I could palm it off to a plasterer however its my house and I am extremely low on funds.
It's not a huge hole in the wall, ill give the cement and multi finish a go on that bit and if it looks pants then ill spend some money ;)
i wouldn't bother with the cement. if your cables are not protected with capping or some such, the cement will degrade the cables' insulation. bonding plaster will not.
