Can't see what the wholesaler has to do with it, get and replace the dimmer and argue the ---- with them later.
You was worrying me a tad earlier when you said about digging paperwork out and nightmare to find ..... whats wrong with filing systems month and dated, also im on line with all my wholesalers and can type in a product and id get instant recall on discount, last time i ordered it etc ..... you sound a tad dis-organised in the least and note the tax man can call on your accounts any time and large fines can be imposed on poorly managed accounting etc.
What you need is a better filing system or a PC based software package like Intuit Quickbooks - which is what I use and can locate such details in a couple of minutes. Mind you you have to be organised in the way you keep your data.
Mate just buy another from the wholesaler, replace the knackered one in the clients house for free as its still under warranty
repackage the blown one and keep it and the reciept on the dash of your van
give it about a week later then return to wholesaler and get refund
whats the fuss about?
If it was bought new then manufactures warrantee should I would have thought would cover it no matter what your whole seller says so I would get it back to him before your year is up and even then goods should have a reasonable life span if not misused consumers act 1979 I think it was so you fit the replacement free but the item costs you nothing
I always allow a prelim cost to any job, usually 5% of the total for maintenance, so if you price a rewire of a house at 2.5k then add 125 on the top to cover any labour incurred during the 12 month period, unless of course you are desperate for the Job and are prepared to gamble on no visits during the period, however the customer should not suffer in any way, change the blinking Dimmer FFS.
all of this over a 800w dimmer ? which is expensive ?? you sure ? lol
Its an 800w brass dimmer mate don't know bout you but £40 is £40 to me.
Anyhow I found paperwork within minutes because I file all my receipt by month to month. Just thought it would be a nightmare because of the amount there is there.
Im ready to bite the bullet as my wholesaler doesnt seem to want to discuss it. Even though I give them thousands worth of custom every year.
Because I supplied it to my customer it is my duty to replace it. But I was also supplied it by a wholesaler.... which should in turn replace it for me. Its under 10months old!
Do they want your business??
Kick your wholesaler in the Pants, My recommendation would be to start using another until they ring in a few months asking why you have not been in lately, when you tell them, they will probably give you a couple of drums of cable as way of an apology haha, been there and done it
I get that £40 is £40, but at the end of the day, bad word of mouth could be more damaging.
I would just change it soon as and be done.
but like dp said- make sure it's up to the job. you don't need the hassle/embarrassment of having to go back again...
The duty you have to the customer also applies to the wholesaler to you, they never like doing returns but it is what it is, fit a standard light switch while you deal with the return, any customer will realise it may take a week or two to get a replacement.
Then rain hellfire upon your wholesaler....:rant:
It controls 2 chandeliers. Each containing 5 60w candle bulbs.
Thats 600w max load. This is 800w dimmer it should be well upto it sjould it not? Or is there some sort of rule ..
I tend to give a margin between rated load and actual load ... i would have gone with an 800 but always read the distructions as each brand may differs, many dimmers also give different rating with re' to lamps in use i.e. Diochroic lamps can have you derating the dimmer by up to 50% where as some dimmers are designed to be used with such lamps at their tabulated rating.
As we dont know the make and model we cant advice but the golden rule of thumb i was taught is RTFM or RTFI
I = Instructions M=manual
