post the spec sheet for the cameras before u go out and spend over a grand for cable that is not needed
gn3 isnt the regs is it ?
and how does changing a socket to spur make any difference to v.d. ?
the spec sheet will tell u what the min voltage the cameras will work at , do the calcs and as long as its above that min then u are fine , as long as the sockets are for the camera use only
Volt drop applies to every electrical circuir regardless what voltage is used.or what is connected to it. A camera doesnt get special dispensation.
i would expect cameras to work at 220-240v just like any other piece of electrical equipment licensed for sale in the UK.
the max v.d. limit of 5% for power is set by bs7671 , not any manufacterer.
