I think it's a valid point that if an RCD had been installed it might have prompted previous investigation into that particular circuit due to 'nuisance tripping' over time. There's always also a chance it could have saved her life as well. I'm not a fan of relying on RCD's as the only means of protection (read TT systems with high Ra values) but given their low cost and ease of installation maybe it's time to make them an 'across the board' legal requirement in domestic properties. If the government came to the party with some kind of subsidies it wouldn't be unfeasible to get them in every house in a year or two.
Agree, no brainer for all households. I am doing my bit by slowly introducing them to my commercial clients when i make an alteration or attend a fault. There is a long way to go.....and Schneider charging £44 for a C60 form B20 RCBO is a bit of a downer.
Getting BG from screwfix at £15 which is better.
I think i should also get my own house in order, still have 16th board with no RCD on lights. Cobblers shoes and all
and what's wrong with that? bet you get less nuisance tripping than a lot of newer installs. anyway, in your own house, the installation is under the control of a skilled person. LOL.
I've still got an old Wylex fused board that has been converted to MCBs!
EAWR 1989 was quickly followed by guidebooks using the same information, I was quoting (from memory) from one of them:
Up to 0.5mA - this is the threshold of perception and has no ill effect, aside from a possible "tingle" and is independent of the time factor.
0.5mA - 10mA - unpleasant but usually no harmful physiological effect and the theshold of "let go", which is the maximum value of current at which a person holding live electrodes can let go of them.
10mA - 500mA - in this range the threshold of ventricular fibrillation is more and more likely as the duration of current flow increases.
At 500mA it can take as little as 100ms to cause reversible disturbance of heart function and cardiac arrest, therefore at between 10mA and 29mA this will take longer but the RCD won't trip, you will be above the "let go" threshold and you will need somebody around who can resuscitate the victim!
Later in the book it says - as little as 2mA can be fatal if the duration of the shock is long enough.
Now the death of this young woman is very sad. But is she the only person to be have been killed by faulty workmanship?
Thats quite true Dillb, infact dying from electrocution is as rare as rocking horse poo if you think about it all, very rare indeed and perhaps david just needs a bit of attention here , for you David :grouphug:
But deaths by heart attack have gone through the roof in recent years and the use of RCD's prevents burning of the skin!
So how many heart attack victims have been found near radiators/kitchen sinks/baths or other un-earthed conductors?
statistically a lot of people die on the toilet,but it doesnt mean having a crap is dangerous
I don't know, and to be honest not really interested. Maybe we need to go back a few thousand years and eradicate the planet of everything that could potentially kill someone.
considering tens of thousands of people have heart attacks at home I would say your answer is a lot, but junk food and high blood pressure is the reason 99.9% of the time not electric shock David, come on man get a grip with all this talk, you had several answers to your question and even the RCD bit, you can't rewrite the regs book Bud.
- - - Updated - - -
:smilielol5: best post of the day, brilliant LMAO
Probably less than the amount who either worry themselves to death about the possibilty of being electrocuted, or the number who run round in circles clucking about the sky falling and keel over due to the exertion.
You all still seem to be ignoring the Law!
Regulation 8 of the EAWR tells you that the metal stud partition should have been connected to the earthing system, it wasn't.
Connecting the metal stud partitioning to the earthing system would have prevented the danger, no arguement.
Maybe you are correct, but that isn't going to bring the young lady back is it. Mistakes happen that's part of life unfortunately.
No it won't bring he back, but it may get justice for her family.
You need to accept the truth if you are to learn by your mistakes and prevent similar instances happening in the future.
