Tragic. However, one point. If a screw has been driven only into the live wire, you could IR test it all day long until your battery ran out and get perfect results every time. If the screw had gone across L to N or E then the fuse would have blown.
ive already mentioned that greenie in an earler post, the grid was live and stand alone the current was present within via the screw- the water ran onto the floor and made contact with the base of the grid she probably knelt in it then touched the stop cock the was electrocuted
Appreciate that.
I just found it odd that the coroner focused on the testing of the installation. Fair enough, the testing would seem unorthodox in that someones mate did it etc. He may have been unqualified but was he competant? Also, no questions seemed to have been asked of the guy that installed the circuit. Did he route the cables out of the way of where the plaster board screws were likely to be fixed? (ie dead centre of the frame) Easily done if one side of the stud has been lined but what if it's just the framework up?
Was the testing done before the plasterboard was mounted? Whoever put the plaster board up, did they make a note of where the cables were run?
It's a minefield out there sometimes and incidents like this are a stark reminder to us all that we have lots of peoples lives in our hands.......
your totally right faa greenie, unfortunatly that lovely22 year gal is dead
thats about it
lifes cheap
It's going to be extremely unlikely that 2mA is going to kill you. Maybe if all the conditions were right at the time of the shock and the length of time you received the current, but apart from that forget it. Generally speaking European high sensitivity RCD devices are set for these conditions, 10mA being the threshold of muscle contraction, 30mA as being the threshold of respiratory paralysis.
16th Ed - not 17th, so unlikely RCD protection would have been a factor at all. Possibly earthing wouldn't have been a factor either - though one has to question where the bond to the water main was.
im assuming its a plastic water main, with bonding above stop cock, when she stood in the water and touched the stop cock she completed the circuit.
telectrix,
Hello again, are you going to explain how an RCD would have saved the day, or are you just on the wind up again?
when she made the circuit the rcd would have tripped within 0.4 of a second and saved her IMO, for the record I have had belts of 240+ volts and where several fluorescent lights were on the circuit and still here, I have read somewhere for my 2 pence worth it takes around 8 MA to potentially stop a heart thats why a 30 MA RCD functioning correctly should trip in 25% of it's rating in a fault condition hence the need for testing them to obtain readings within the scope directed by BS7671, Not saying I know for sure David, but I have read that somewhere and will try to clarify that for you later on.
ok I'm not reading this thread anymore ffs.
These 2 little wires going down into my heart from my pacemaker are starting to worry me now............2 pairs of plastic gloves on from now on instead of just one :)
2mA ffs.................arghhhhhhhhhhh
First of all f&r we're talking about a dead girl here so cut the sarcasm!
telectrix - 2mA is the lethal threshold, who told you it was 30mA?
here we go again, mr know nothing cockburn strikes again,30 mA and above is generally accepted as the threshold for a fatal shock.But then again you're the expert,after all you have written 2 books full of nonsence which were heavily criticised by the IET haven't you?
from: An Illustrated Explanation of Automatic Disconnection of Supply
(Paperback)
I don't even need to read this in order to review it. Let
the Institution of Engineering and Technology have their say:
"The IET
were sent a copy of this book . We told the Author that it was heavily flawed
and inaccurate when he asked for our opinion of it. We do not recommend this
publication as a reference book and it should not be used as such."
Mr
Cockburn is either a wind-up merchant with a deep and unfathomable sense of
humour, or else is a dangerously deluded fool.
From what i have seen this winter with RCDs, if an RCD was fitted to the circuit which had been damaged i believe she would be alive for two reasons:
1. I believe it would have tripped before she even entered the area.
2. Even by some twist of fate it had not, there would be some current imbalance already from the water touching the metal partition, if she enhanced the cct by touching an earthed component whilst stood on the wet floor at 240V , she would only have taken a portion of the imbalance before the RCD tripped and most i have tested let go around the 50mS. Even if this was enough to stop her moving the supply is off and no further shock can occur.
Absolute tragedy, agree about - who can be blamed. Struggling to understand how much the IR test would have picked up a nail into the live wire and then the partition. It depends how good the partition was insulated from earth. He may have got a small difference in Mohm reading but as everything was damaged by water how would anyone know what that reading would have been.?
Agree mate,but unfortunately some people only fitted rcd's if there was a chance of power being used outdoors,I worked for a firm years ago and rather than fit rcd at board they fitted 1 rcd socket in hallway labelled "for equipment outdoors" because in the bosses words "it's cheaper" as regards an ir test picking up the fault then as I see it if it was only the live wire that had become "connected" to the steelwork due to damage then the only way this would have been picked up was a test between live and the steelwork,many years ago this steelwork would probably have been bonded to earth,back in the days when even metal window frames were bonded.Maybe this raises a case for bonding such materials when used in a bathroom.several years ago I was asked to finish off an industrial unit as the other spark had disappeared and in places he had run cables through a similar type of structure without using bushing,the wiring was severely damaged and had to be replaced.
I think it's a valid point that if an RCD had been installed it might have prompted previous investigation into that particular circuit due to 'nuisance tripping' over time. There's always also a chance it could have saved her life as well. I'm not a fan of relying on RCD's as the only means of protection (read TT systems with high Ra values) but given their low cost and ease of installation maybe it's time to make them an 'across the board' legal requirement in domestic properties. If the government came to the party with some kind of subsidies it wouldn't be unfeasible to get them in every house in a year or two.
I'm going to post the reg that stipulates cables running in walls with metallic parts other than screws and fixings must be protected by RCD, which in the case of modern build means the metal stud work
that's true now, but was not a requirement under the 16th.
Some commercial buildings use "partitions" that are metal cased in fibre/plaster board, not seen them earthed, also suspended ceilings, OK the recessed lights are earthed but are painted, i see cables just run across the top of them, they have sharp edges and all. Very difficult to earth with so many joints.
Makes you think - what could happen.
