I think I'm spending more time trying to work out how much to charge the customer than the job itself!
After a few months I'll get a general idea of how much to charge for jobs but for now I'd be grateful if a few of you guys could give me an idea what you would charge for the following in total for the following job all in the same house:
1. removing existing uplighters and fitting 2 new uplighters to wall - cable already there.
2. Adding 2 spurs - using trunking, customer doesn't want walls channeled
3. putting 2 lights into loft - access isn't difficult, low ceiling, will take power from existing lighting circuit
4. Testing
I have done a pre-work survey. The house is RCD protected, lights are earthed, main earthing and bonding are fine and other tests ok so I'm not expecting any complications......oh dear!
How much would you charge for that lot? (for labour)
4. Testing
