In the Emma Shaw case, the circuit was energised for use by trades before completion of the full refurb of the flat, the MCB kept tripping and being reset, due to a screw between the live and cpc.
Eventually the cpc blew away enough, to leave just the metal partition live.
The testing was carried out by someone that was not Competent he admitted it, he even got someone to help him, IR tests may have found something but were not carried out, the r1 r2 test would have.
This is what I was told had happened as well.
It is "reasonable foreseeable" that metal stud partitioning can become charged when you pass non-armoured power cables though it!
Niether the IET or ayone else has so far admitted to reading my second book! Please note the use of the phrase "without even reading it".
I don't agree with what the current employees of the IET say about earthing, I agree with what was said in 1991 (16th Edition of 7671; and 5839-1; and 1989 EAWR).
Wet plasterboard obviously isn't an insulator!
Emma Shaw wasn't at work, but the people who installed the system were!
The EAWR applies whilst you are at work whether in a property intended for domestic or any other use.
If alterations/changes are carried out after you have left and before your next scheduled test, you will obviously not be held responsible for any accidents that occur as a result of those changes.
Neither does having an NVQ. If you have £500 to £1000 and a camera you can get an NVQ.
well said,back in the day you did your training sat your C& G and passed or failed.now with NVQ its all modules,get one wrong and its ok just sit it again,unfortunately life isnt like that,in the real world get it wrong and you could have a fatality on your hands.
Unfortunately the earth book still has a drawing missing and some of the terminology is still in 'slange', but the general principles are correct.
The idea of releasing it anyway as it was, was to try to help the IET as they had obviously got confused over earthing when copper pipework changed to plastic. In all honesty I expected help from them on the subject, but then when I suggested using RCD's as "the least they could do" they leapt on the idea and started this myth about RCD's being able to replace earthing, when in truth they can only supplement earthing.
City & Guilds 236 1&2
Each and every one of my qualifications is of the highest grade possible in that subject.
Your problem with metal stud partitioning has come about recently with the invention of plastic socket/switch boxes! In my day the partitioner would put noggins in for you also made from a short length of the same metal stud, then simply fixing a knockout box to the noggin gave you earth continuity with the studwork.
This is why I have said we need to learn by our mistakes!
my uncle is a top engineer with more degrees and hnc's than you can shake a stick at doesnt stop him talking crap at times.you wrote a book which was poorly written just leave it and move on.
Tony the IET don't like my second book because it reveals the true meaning of the terms 'radial circuit' and 'radial system', it also points out that we should be using 25amp BS EN circuit breakers on 2.5mm ring final circuits and 20amp BS EN breakers on 4.0mm so called 'radials'!
All a bit embarrassing for them and the Fire Alarm industry!
David, it wasn't the IET who wanted to use your idea of replacing earth with some gadgetry, it was the little green men. You know, you remember them....the ones who put that tube up your...............
Shssh.....must go, think they're watching me......hide..........
Don't you like my qualifications phil?
its not a matter of the qualifications it's the knowledge that counts,I fail to understand why you published a book that by your own admission was incomplete/incorrect.In my opinion your time would have been better spent doing a bit more research and producing a quality article,as for trying to advise the IET of their alleged errors also this would have been better done by a direct approach than in a book.I do not for one minute believe that the people at the IET are less qualified than you are.Having a little knowledge does not make you an expert,I starred in a film a few years ago,but I would never consider myself such an expert as to tell the likes of Sean Connery how to act.
"About the Author"
David Cockburn is an Electrician who was given a start in the industry by his Father.
Nearly a decade and a half of practical experience preceded a highly successful college education, followed by a promising individual career in Electrical Installation.
Latterly David has spent his time educating himself in the field of British and European Electrical and Fire Alarm Installation Safety Standards.
Well, maybe the guy actually CAN be an author - of fiction!
