What was another electrician even doing near your Mum's electrics mate? Was it not mentioned until the day, and she just agreed to whatever they said?
Just that, She aggreed to the work and the guy did the work.. She said she was sure it was the same guy doing to plastering...
""Alarm bells""
Where/what is the reg that says a cpc has to be run to every accessory?
I just cannot find it!!! :banghead:
Ask the firm for the MWC with the test results on, as he had extended the existing lighting circuit. :)
If there is no reg then there should be.. Its just sloppy even in this case it would have been avoided by just using twin and earth as opposed to just 2 core flex..
What a load a tripe! if the earth is there put it in. Not everything comes down to a reg, if it did where does the common sense fit it?
Thank you Richard!
I knew it was somewhere.
I'll ignore post 21, he obviously can't see where I'm going with this...
I can see where you are going with it. I never said an earth had too be there but is it not just good practice instead of leaving it in another rose above?
After a long horrible battle he said he did not do any electrical work at the property therefore is not responsible...
So from being the professional compnay and getting everything done by the right trade its now he did everything..
How much do you recon she was charged to drop a ceiling 20 - 30 cm and board and skim.
