yeah yeah your all the best, why not try helping instead of well really just rude comments
mdj can you tell me why no replies then, this way i can look at myself and try to change this
Okay, here's the thing, You have installed an electrical transformer with a 25mm2 armoured cable to it probably on a building site for use by tradesmen who use 110 volt tools. You have done this and yet do not know whether the RCD is 230 volts or 110 volts, you also do not know how to test this device or are not even sure if you have the means to actually be able to test it, very concerning, we want you to tell us and give a bit before we can help, is it on a building site? how have you protected this unit? what test equipment have you got? are you intending to certify? if so as a temporary installation? there is much more you need to tell before gaining help, where is the RCD housed in the unit? what is it's purpose? give and we may give.
its on a building site...its fed from an 50a mcb, they dont do 50a rcbos so ive been told to use an rcd at the tx unit itself and test it, this is where im getting stuck as the best thing for me to do
You do know that you can only get a 55 volt belt from a centre tapped 110 volt tranny? the secondary winding is tapped, just thought I'd chuck that in to make things more confusing for you?
haha, i do understand this.....im just not sure myself to be honest, ive not had much to do with installing 11ov tx's, i just plug my drill in and use them......however ive been told to get rcd protection, maybe the aroured needs the protection, if the tx does not, have you ever installed an rcd to protect the secondry side, by this i mean when you plug your 110 drill in is that rcd protected, i understand im not explaining myself that great here......above the 110 sockets are mcbs, should i put and rcd here, one of the tx's already has one as its a second hand one been sent out
can i tell you that i studied for my 2391 and passed it without looking at past papers, i know you think im stupid and your prob right but i am trying here
- - - Updated - - -
i did wonder if you got a 110 commando socket to plug into the yellow lead from the tx to test rcd
Another question, when you connect the armoured to the transformer where do you connect the armoured to if there is an rcd in the front panel with mcbs next to it? have you ever lifted the top off a tranny and looked inside?
to be honest mdj i dont know, can it, i thought it could test all different voltages, my head hurts mate
