ha ok, it was terminated into the rcd, then it goes to primary side then sec side then breakers am i right here
so, am i right here, rcds are used for hard wired ltg circuits only just to stop the need for increasing cable size, so the tx itself def does not need rcd protection.....only the armoured cable feeding the tx would need this, do you think that25mm is to big as a feed although the run is 70m...and how can i rcd protect this, the mcb is 50a and they dont do 50a rcbos....
ok, i have been looking around and found some debates, to my understanding it is possible to protect multiple circuits with one rcd in the site tx, and an rcd used to protect hardwired festoon ltg allows you to use longer lengths of smaller cable. so if i had festoon ltg hardwired in my site tx protected by a 30ma rcd as stated by blakely electrics (although ive read elswhere it should be 10ma) i would still need to test the correct function of the rcd....as ive never done this before im guessing i would need to go to the last light on the festton ltg and test l terminal n and e terminal with the prongs of the tester and hit the test button......it doesnt state in the regs that you have to protect the armoured feeding the tx with an rcd either.....just confused with this and lots of different people have lots of different answers
ha, i was sent an rcbo to protect the secondry side of the tx, in front of the dp mcbs.....to my understanding this only protects l1 from overcurrents not l2, but i was told its ok it works, the double pole 230 or even 400 v mcbs are protecting that.....what do you think
