Always keep a volt stick in my pocket, whilst not fool proof they're handy when you don't have your voltage testers to hand.
I have a small flat mirror in my bag. Mainly for checking buss bar has gone into the mcb's properly but it does have other uses too
M4 tap and accessory screws for when back box threads are really really knackered.
Can you get silver coloured M4 screws? Whenever I've tried I can only find brass ones.
Last week for the first time I had to use the trick of drilling a 3mm hole in the back of the box and threading that, as the moveable lug had busted off.
I have a pliers type crimper, for cutting 3.5 or 4mm pins, it cuts them and does not ruin the thread.
a mate off mine at work has the smaller set and they are very good
http://www.amazon.co.uk/C-K-39071-R...197&sr=8-2-fkmr0&keywords=ck+side+cutters+4mm
they have holes in them for 3.5 and 4mm pins
