S
SPARTYKUS
My turn to post....
got a very elderly neighbour (mid nineties) sharp as a lemon.... And a flourescent light in the kitchen that looks from the 1950's...
The starter has gone - its bigger than any one I have ever seen and has "BS 2818" on it (regs for starters, 1985).
does anyone know if you can still get them.
thanks.
And before anyone suggests it, yes, I know a new 5 foot tube is a few quid but its the principal I want to see through, the customer would like to keep the fitting if possible!
Is it about a 1" in diameter and metal case by any chance? If so last time I saw one of then was the 70's and they where like rocking horse poo then.
Hello Ian
yep you guessed right!!!
As Hugh Grant said in that film
"baggah. Baggah, baggah baggah baggah"
Im ashamed to say ipf I still haven't sussed the joke but I am slower than homer Simpson doing a 100m sprint with jokes. Give me a week
If you have to change it, ask him if he'd like a twin fitted (if not already). When you're getting on a bit, you appreciate some more light to offset the failing eyesight.
Edit: Plus, if one fails, you're not without some light.
Can you not rob a more recent fitting of it's starter base and put it instead of the original then put normal starter in
Hi itselectric yes considering that, got loads in moon base alpha (stock store).
just wondering if its worth it!
Not sure but I might have the odd one hanging about in the old stuff, somewhere. Not worth the trouble though, it's probably used.
Could try OES
SPARTYKUS,
Deleted member 72666,
