C
craigdiver
I'll take a some photos tomorrow and post so you can cringe at the setup!
In a way that is good, it strongly suggests the problem is the fact that an MCB has been installed where it shouldn't be.
In your situation it appears that the designer selected fuses which have been doing the job fine and then someone else added an mcb which hasn't been so great.
Cooling water? Are they Lincoln welders?
shorts out to what ! .... its a low impedance coil it will show dead short if meggered ... thats the way your post reads or do you mean to earth?
