S
shurbunkin
hey guys
ive wired in a 3 phase motor for a work shop and i think ive connected the phases right. It doesnt need a nuteral and the earth is bolted to the metal work. ive switched it on but when it starts the motor runs for about a second then stops and the breaker trips. Its got a 16amp thre phase breaker supplying it. I think it needs a 20amp. Just wanted to make sure incase i damage the equiptment.
The connections ive made are l1 to w2, l2 to u2 and l3 to v2 of the motor and have metal links between w2 and u1, u2 nd v1 and v2 to w1
cheers guys
I cant seem to attach a picture. I copy the picture in and im told the url is too long.
The breaker is a 16c type breaker
far too little info.
1.star or delta? 2. what size cable feed? 3. does starter have an overload?
answer these and we might be able to hepl.
help even
pt pic on desktop on low res. then add image from computer.
its for a power unit driving hydralic pumps. The motor rating is correct. Im wondering wether i need to put i higher breaker in
taking the board cover off the cable size between the board and the comando socket is 2.5mm which seems way to small
Oh for god sake get an electrician in will you!
"I think I've done it right???"
Do you now?! Well my friend, if you were competent to be carrying out the work in the first place you'd know if you'd done it right!
FFS! I feel like crying sometimes!
shurbunkin,
Besoeker,
