Help identifying permanent live and switched live – replacing two-way switches with Varilight V-Pro Multiway dimmers
Hi everyone,
I'm replacing two existing Hamilton two-way bedroom switches with Varilight V-Pro Multiway master and companion dimmers.
Both switches currently control two wardrobe-mounted lights together. I'm also replacing the existing halogen transformer with a Varilight YT40DC12 dimmable LED driver for new 12V LED lights.
I've photographed the existing wiring before disconnecting anything.
Switch 1:
  • COMMON: Brown
  • L1: Grey with brown sleeving
  • L2: Black with brown sleeving
Switch 2:
Three cables enter the back box:
  • Cable A (brown, black, grey): Brown to COMMON, grey to L1 and black to L2.
  • Cable B (brown, blue): Brown to L1, blue joined with the other neutrals.
  • Cable C (brown, blue): Brown to L2, blue joined with the other neutrals.
  • Earth conductors are connected to the metal faceplate.
My understanding is that the black and grey conductors may be the strappers between the two switches, but I cannot establish which brown conductor is permanent live and which is switched live.
Could someone explain what circuit arrangement this appears to be, which tests would be necessary to identify the conductors safely, and whether Varilight's Figure 2 or Figure 3 is likely to apply?
I understand that the connections cannot be confirmed from photographs alone.
I've attached photographs of both existing switches, the cable groupings and the Varilight installation diagram.
Thanks for your help!Switch 1.webpSwitch  1.webpSwitch 2.webpMaster dimmer.webpCompanion dimmer.webpDimmer wiring.webp
TL;DR
I'm replacing two existing two-way switches with Varilight V-Pro Multiway dimmers (master and companion).
I need help identifying which wires are the permanent live and switched live, and which wiring diagram applies to my setup.
Please see the attached photos of the existing wiring and the manufa
The permanent live and switched live are the brown conductors connected to L1 & L2 of the switch with the 3 cables, although not necessarily in that order.
You really need a voltage tester/multi meter to correctly determine which is which without over complicating things.
The center drawing clearly shows a 2way circuit, so just follow that once you have established which is L and SL.
