1P + N does not break the neutral!
HappyHippyDad
Supporter
Evening all...
I have just had a long call with BG trying to find out if their 50A RCBO breaks the neutral, as it states 1P + N for number of poles.
I just assumed 1P + N meant it broke the neutral in the event of a fault but only detected over current in the line.
However BG have categorically said it does not break the neutral.
is this an error on their data sheet or am I misunderstanding the term 1P+N?
From what I can make out the compact versions do however there does not appear to be a 50A version. The 50A version is the taller style and from the schematic on it does not break the neutral.
So... What is the definition of 1P + N when that is written in the spec after 'Number of poles'?
I will try to attached the data sheet.
AI defines 1P+N with regards an RCBO as breaking the neutral in the event of a fault.
The data sheet clearly isn't correct.
As already said looking at the info on the device it is also clear that there is no switching of the Neutral.
It just denotes the number of poles 1P+N. It does state how many of those poles are switched.
