Discuss 20% rule in the Canada area at ElectriciansForums.net
O
ONIT
Has anyone come across 20% rule on the new 17th ed boards
Is it on the whole of the board. or each sub section, ie 20% fist rcd, 20% second rcd ect. ect.
cheers....
sorry if installing new cu you would leav 20% space is ,, ie 8 circuits 10way cu,, 10 circuits install 12 way cu so (20% expansion space) is it on all the board or each sub section
So if installing 17th ed board with mains isolater, rcd 1 ,, rcd 2.. would you have too leav 20% expansion on each rcd i hope thats a bit more clear
cheers
ahhhhhh! now i understand onit is on about spare capicity .as far as im aware there is no requirement to leave any space spare. if you fill one board then add another and another.........
we tend to go for 25% spare the current db im doing has 50% spare ,but thats the client s choice ! (24 triple pole ways)
Reply to 20% rule in the Canada area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Good afternoon - we're considering adding an additional breaker to our "main service panel" which is where the meter is located. That panel has 6...
Ukpn have put a supply in for us to feed an outside cabinet, which will eventually supply foul water, sewage pump's. They have supplied an earth...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
