Aico 3000 Range
Discuss 25mm Flexicon Coupler in the Electrical Tools and Products area at ElectriciansForums.net
hi all I’m after some 25mm flexicon couplers to join my already bought 10m lengths of 25mm flexicon conduit.
This is one of those cases where I should have done more research before buying...
I cannot find a coupler to join 2 pieces of 25mm flexicon anywhere!
Flexicon won’t sell to me direct and no one local will buy them in!
It will cost more in diesel to get a refund from TLC and go buy a longer length.
Anyone know where sells a solution? 25mm coupler to join 2 male threaded ends.
Cheers
Instyle LED Lighting Specialists UK
James
Mentor
Supporter
what is the part number of the conduit that you have?
when you say 25mm I presume we are talking about corrugated plastic, PVC or PP.
it is possible to get a conduit to conduit connector, but you could also use a 25mm rigid conduit coupler and just screw the m25 fittings you have got into each end of it.
Put a small adaptable box in to join them.
telectrix
Mentor
use a 25mm galv. coupler.
James
Mentor
Supporter
like this, left partialy unscrewed for clarity.
p.s. you can get the same in plastic
telectrix
Mentor
but westy has a good point. fit an earth tag to it. good luck with that. :D:D:D:D:D
Strima
That will require an earth if it contains mains conductors.
I thought the OP was using the metallic Flexicon?
If using plastic then two female adaptors with a short length of 25mm conduit glued in the middle.
telectrix
Mentor
or a 25mm plastic coupler and gorilla snot glue.
James
Mentor
Supporter
I have a huge stock of all sorts of flexicon fittings, let me know what conduit type it is. I will stick you a coupler solution in the post for a beer.
  • #13
I bought Flexicon FPP-CP25B
I can’t it’s being sent underground through an existing channel.
I was just looking at those but wasn’t sure how good the fitting was gonna be.
No mains, Ethernet
Blimey really?! Decent people still exist??
I’m only after 2 couplers for FPP-CP25B.
I have 3 10m lengths that I want to join to 30M
Thank you all. I didn’t realise you had all posted, no email to say it had been responded too!
James
Mentor
Supporter
No mains, Ethernet
By the looks of it the simplest solution is to use a 25mm galv coupler, you have bought contractor packs so you will already have the conduit to m25 male thread adapters in the bag.
Any questions then feel free to pm me.
Electrical2go
Official Sponsor
Hi,
We do the earth couplers in 20mm or 25mm.
Let me know if you need one and we can drop it in the post for you.
Cheers,
Ivan
Reply to 25mm Flexicon Coupler in the Electrical Tools and Products area at ElectriciansForums.net
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Top Bottom
