Searching shows these both comply to AS/NZS 3123 standard so in theory should be compatible.I have a 3 phase (male) NHP ISOP P5532P plug that fits into a (female) Clipsal 563 540 socket, but won't go in deep enough for the threaded collar to screw on. It only needs to go in another 2-3mm. Hints please?
It sounds like you're really close to a proper fit, but that 2–3mm can make all the difference with these types of industrial connectors.I have a 3 phase (male) NHP ISOP P5532P plug that fits into a (female) Clipsal 563 540 socket, but won't go in deep enough for the threaded collar to screw on. It only needs to go in another 2-3mm. Hints please?
