Wolf865
Finally got the 4-way switch added that now allows us to turn on the garage lights in the kitchen before having to step into a dark garage and grope around for the light switch.
Next thing I would like to upgrade is for there to be some way for us to know if the lights in the garage have been left on without having to open the door to find out?
Been researching the 3-way pilot switch that has the build in indicator in the rocker switch itself. Supposedly illuminates if the lights are on. My new state of confusion is whether it can be used with my current 4-way setup that I just finished? It talks about needing a neutral but as all 3 wires on the 3-way switch I now have in the kitchen are in use, where can I find something to use as the neutral? Even then I've found comments that a 3-way pilot switch will only work on a 2 switch system?
In my cramped little side attic where I routed the 12/3 wire down into the kitchen, I have access to the foyer lights ceiling box which is on the same circuit. Can I just tap onto that and run an additional wire down into the box the pilot switch would go in, or not that simple? Suggestions? Warnings?
If this is not feasible what other indicator options might you suggest? Was thinking of just putting a peep hole in the door between the garage and kitchen. If the garage lights had been left on there might be enough light coming thru that you could just glance at it from a distance and see some sort of illumination coming thru? All these things I should have thought to do 20+ years ago... LOL
