J
Jeffmo65
Commercial scenario :
lets say 54m , mmm ok 16amp OCPD, mmm ok at 52m I think I will put a 20amp D/P isolator , humour me I will go on . Actually oh dear I've ran out of 4mm T/E , tell you what I will just use 2.5mm instead . Anybody see an issue , cable clear run on open spacious cable tray no influences just straight clear run .
I just know that someone will say it's fine cos 2.5mm will take 25 odd amps .
Conversations requested guys
Sorry guys not sure really what you mean . If I've broken some rules then I apologise . Oh and the cable size is after the isolator NOT A FUSED SPUR by the way
Lol , don't worry about it , some start posts like this as a wind up , but it has fallen out of favour in the last few days.
Oh don't worry about VD it's irrelevent ............ Isn't it . Let's see 2.5mm ooh about 40m max . 4mm what about 60 odd . Oh B type MCB BS60898 Schneider acti 9 10ka . Oh bugger lets just put the last few meters in 2.5mm
Hi Dillb . Well this is purely a scenario but I would have thought that the length if you were to carry on from isolator with 4mm then great but this wasn't the question . I've seen lots of installations where other sparks have ran circuit in X cable to an isolator then for some unbeknown reason dropped to cable Y . My question is why not run the whole lot in cable Y if it's ok to use this on the last few meters . I think not . What's your thoughts ?.....??????
