just a quick one chaps, need to connect a 6kw domestic cooker, its wired in a 6mm radial on a 32a mcb. i have some 4mm heat resistant flex from work, is it ok to drop to the 4mm cable from the cooker outlet or do i need to stick with the 6mm csa. i work industrial/commercial so just after advice. thanks.
should be fine on 4mm HR. flex. don't forget diversity. doubt it will ever pull more than 20A.
4mm hr flex
yamar1,
Mr Mark Sparks,
